Lm420 turbo oil feed, what's required
Old 13 May 2016, 10:20 AM
crazyspeedfreakz
crazyspeedfreakz's Avatar
Default Lm420 turbo oil feed, what's required
Ok so I now have a lm420 I cannot fit as yet due to needing the oil feed set up but I'm wondering what's required...
Obviously I need the oil feed, but read on another post that I may need a restricter.... Are they set sizes ? In terms of restricting or is there a specific size I need.
I may call litchfield but the kit they have includes waterpipes which I dont need but doubt they will split the kit.
Any help would be great
Old 13 May 2016, 04:02 PM
I don't know about what you need, but I have x2 new ones here in 2 screw sizes for the block newage avcs/non avcs I think as both are different sizes maybe?
One from blouch turbo and other universal. Got some fittings with it too see if you can make up?
Old 13 May 2016, 04:11 PM
SmurfyBhoy
SmurfyBhoy's Avatar
AVCS joins block at yellow arrow,
Try to get an oil feed to fit where red arrow connects,
Ineeded one of these
Old 13 May 2016, 04:21 PM
Have these if any use once you know info
Old 13 May 2016, 04:24 PM
SmurfyBhoy
SmurfyBhoy's Avatar
Id guess the one on the left, one end on where red arrow in my pic other to the restrictor in turbo.
Can only hope the threads match,
I called up scoobyclinic and the send me one of those little adapter i posted earlier.
Got it next day too.
Old 13 May 2016, 04:25 PM
SmurfyBhoy
SmurfyBhoy's Avatar
That was my setup,
Had to remove Banjo fitting where blue arrow points, and use the adapter.
There will be a direct fit i just couldnt find one.
Old 13 May 2016, 05:45 PM
crazyspeedfreakz
Old 13 May 2016, 05:46 PM
crazyspeedfreakz
2003 Jdm spec c
Old 13 May 2016, 05:51 PM
HEL Performance
HEL Performance's Avatar
If you find out what's needed we can make you one up, it is 12x1 at the block side.
We have male/male restrictors
Also banjo bolt restrictors in different sizes if needed.
HEL Auto
Old 13 May 2016, 05:54 PM
crazyspeedfreakz
Just been told that 100% need a 1mm restrictor
Old 13 May 2016, 05:56 PM
The one on left is a blouch one that cane with kit, and does fit the restricter pill on turbo and other end straight into that thread on head, couple of fittings with it for non avcs heads
Old 13 May 2016, 05:59 PM
Isn't there a restricter pill in turbo? That's all you need then and my line should do it.
Old 13 May 2016, 06:11 PM
crazyspeedfreakz
Spoken to litchfield just before they closed advised I needed a 1mm restricter, I thought the restricter pluged between turbo and oil feed ??
Old 13 May 2016, 06:13 PM
crazyspeedfreakz
Old 13 May 2016, 06:39 PM
HEL Performance
We have 1mm restrictors dependant on turbo thread.
Old 13 May 2016, 07:03 PM
**jay**
**jay**'s Avatar
You must be incredibly lucky, ive tried for info for my t20 and my lm450 for ages, they were not interested in it even though they built it, if it had been a gtr i was calling about then im sure things would have been different lol
Old 13 May 2016, 07:36 PM
Yes restricter goes in that, then oil line on top
Old 13 May 2016, 07:43 PM
You can just about to see the restricter pill if you zoom in fitted here, gold type screw in threaded both sides.
Old 13 May 2016, 07:50 PM
HEL Performance
We have ones like these
https://www.ebay.co.uk/itm/231451708904
And
https://www.ebay.co.uk/itm/231001921881
Also a couple of others.
Old 13 May 2016, 08:19 PM
And
2nd link is more likely, dependant on thread size
Old 13 May 2016, 10:37 PM
SmurfyBhoy
SmurfyBhoy's Avatar
Mine has AVCS.
2003 Sti.
I hadto buy the adapter as my oil feed wasnt the same thread.
Old 16 May 2016, 06:19 PM
crazyspeedfreakz
http://www.ebay.co.uk/itm/Turbo-Oil-...UAAOSwFqJWlgox
Old 16 May 2016, 06:23 PM
crazyspeedfreakz
Old 16 May 2016, 06:30 PM
Wonder if that will fit the hatch
Old 16 May 2016, 06:36 PM
crazyspeedfreakz
After a little bit of a chat with litchfield this afternoon they advised me they don't have the oil feeds so I would have to source else where,...... I think ! Someone told me the entry on the LM was the same as the gt30 and came across these feeds on eBay that I've posted above, I guess the avcs bit will be sound it will just depend on wether it will fit the restricter... On the plus litchfields do have the restricter a in stock lol
Old 16 May 2016, 06:42 PM
crazyspeedfreakz
Anyone able to tell me the difference between the two feeds above and the second one is about half the price
Old 16 May 2016, 07:17 PM
The Pink Ninja
The Pink Ninja's Avatar
Bush/sleeve bearing 'vs' ball bearing...but what the difference is I have no clue
Old 16 May 2016, 07:38 PM
crazyspeedfreakz
Yarp, saw the turbo variations just don't no how it makes a difference to the oil feeds hmmmmmm
Old 16 May 2016, 07:47 PM
I'm confused
Old 16 May 2016, 07:52 PM
SmurfyBhoy
SmurfyBhoy's Avatar
Ball bearing has a small restrictor.
As they take less oil.
You require the ball bearing.
Quick Reply: Lm420 turbo oil feed, what's required
