sti v1 intercooler help
Old Jul 21, 2014 | 09:52 PM
steven81's Avatar
steven81
Default sti v1 intercooler help
Am wanting to upgrade my intercooler but keep a top mount can I fit one of a later model if so which one will be a direct fit thanks for your help as always
Old Jul 22, 2014 | 07:44 PM
myblackwrx's Avatar
myblackwrx
You can fit later model versions but none are a direct fit iirc
Old Jul 22, 2014 | 09:00 PM
steven81's Avatar
steven81
Would I gain anything from fitting a later one?
Old Jul 22, 2014 | 09:34 PM
myblackwrx's Avatar
myblackwrx
The later ones are bigger and straight but I doubt you would see any gains.
My 93WRX ran 270bhp with no problems on the standard tmic
Old Jul 22, 2014 | 09:40 PM
steven81's Avatar
steven81
Thanks for the info think I will leave the standard one on then
Old Jul 22, 2014 | 11:13 PM
dj219957's Avatar
dj219957
you can put a later one on, but its a lot of work.
Old Jul 22, 2014 | 11:19 PM
53's Avatar
53
ARC if you can find one
Old Jul 23, 2014 | 07:34 AM
staaf's Avatar
staaf
Recently read on another forum, the TMIC from an WRX Hawkeye should fit with minor modifications.
Haven't seen it myself just read it.
I went for the STi Slanty Tmic because my WRX slanty was ready for recycling
Old Jul 23, 2014 | 07:40 AM
steven81's Avatar
steven81
Yer mine is a sti one with water spray going to fit full 3" exhaust and panel filter then get it mapped didn't know if the intercooler would restrict it but don't want a front mount
Old Jul 23, 2014 | 08:23 AM
MattyB1983's Avatar
MattyB1983
Yes you can fit a later top mount and yes, they are certainly an improvement over the tiny slanty early ones.
However, it's not a simple bolt on job, it does require some work.
I now have a fully restored and modified V4 STI one to go on my early STI RA. The first thing required is to blank off the dump valve port on the larger cooler. This requires you to cut it off the cooler and weld a plate in its place. You also need to cut down the throttle body and the tube itself on the cooler where it joins the throttle body.
You will also need to make a bracket to hold the cooler in place.
Like I said, it's not an easy job but if like me you want it to look original but still upgraded from original then this is the way forward.
Yes the ARC ones are good but they are rare and expensive when they do come up. And I'm not sure they are really much better than a later OE one anyway.
When I get home I'll take a few pictures of my one and post up.
Old Jul 23, 2014 | 08:29 AM
steven81's Avatar
steven81
Thanks for the help
Old Jul 23, 2014 | 01:34 PM
53's Avatar
53
Track use, 300bhp and det no greater than 29 on a fully solid bushed car They are better IMHO The important part being the much wider bars in the core increasing capacity substantially Look at the tests done in Autospeed, the ARC one is identical to the after market version 2 AVO one, pretty much
If you drive a Version 2 WRX you're severely limited by the tight clearance between the throttle and firewall. As we've seen, however, you can achieve excellent heat exchange and airflow improvements by fitting a quality aftermarket intercooler (such as the AVO 'cooler) along with a smoothly contoured feed pipe. If your budget doesn't extend to an aftermarket 'cooler, the only options are to fit a smooth feed pipe (again, like the AVO part) and maybe a water spray system for the core. Oh, and you might also want to enlarge the charge-air inlet in the rear end-tank - STi certainly thought it was worthwhile.
Also don't forget to ensure the ducting to and through the intercooler is mitigated I have modified my scoop skirt to ensure a flush pressure fit to the core to ensure all the air is forced through the core. Any straight fit coolers fitted will not align with the V2 bonnet scoop arrangement and will be counter productive if you don't make a quality effort at ducting the air to an effective pressure fit.
My ARC
I've cleaned the bay since lol
Hope that helps, as with anything the end result is only as good as the job you make of it
Old Jul 23, 2014 | 08:54 PM
mickywrx's Avatar
mickywrx
Unmapped 12.4s @ 105
From: Newcastle. 330bhp-289lb/ft @ 1bar boost - 12.4s @ 105mph
Post
Samco inlet pipe! Far too much money, Stu.
Old Jul 23, 2014 | 09:06 PM
MattyB1983's Avatar
MattyB1983
Did they do any testing on inlet temps ??
The ARC one flows more air and it's core volume is larger but is it more efficient at cooling it and by how much ???
I'm sure they are a great bit of kit, and if they were cheaper then I'd have one. But I just can't warrant £200+ on a top mount that isn't 'that much' better if you know what I mean.
I'd go front mount before I got near the limits of the top mount anyway.
Here's my V4 STI one after some love
This will be more than adequate for my current needs, plus I think it'll look better than the original
Old Jul 23, 2014 | 09:11 PM
MattyB1983's Avatar
MattyB1983
I'm desperately jealous of your samco hoses though...... :-(
I think they are deffo next on my list.
Old Jul 24, 2014 | 06:59 PM
mickywrx's Avatar
mickywrx
Post
Fraction of the price if you don't need the breather and recirc take-offs.
Old Jul 24, 2014 | 07:02 PM
MattyB1983's Avatar
MattyB1983
Unfortunately I do need the take offs as I'm trying to keep it looking as stock as possible. Just want to upgrade the hoses without them looking out of place if you catch my drift
Car Parts For Sale
1
Nov 18, 2015 07:49 AM
