thoughts on thermostat upgrade ?
Old Jun 26, 2014 | 11:46 AM
wrxmargy's Avatar
wrxmargy
Default thoughts on thermostat upgrade ?
Heyy yalls !
My radiator on my 2004 wrx is looking abit tired so im going to get my self a mishimoto one to replace, just thinking really while I'm there would a 160 degree thermostat benefit me ? I'm all about keeping things cooled down but have read some Americans rowing on a forum about having to change oil ect ect blah blah, just want good info straight to the point lol ,
Regards
Old Jun 26, 2014 | 05:13 PM
wrxmargy's Avatar
wrxmargy
bump
Old Jun 26, 2014 | 07:22 PM
mickywrx's Avatar
mickywrx
Unmapped 12.4s @ 105
From: Newcastle. 330bhp-289lb/ft @ 1bar boost - 12.4s @ 105mph
Post
160 degree!?
Your engine would have died long before the temps got that high.
OEM works just fine, or you could try something like the ZeroSports.
Worth doing a search and having a read though:
https://www.google.co.uk/?gfe_rd=cr&...rmostat+subaru
Old Jun 26, 2014 | 07:45 PM
trevsjwood's Avatar
trevsjwood
you need the oem one for normal use, lower temp thermostats don't work well in winter, lowering oil temps to much in cold weather.
Trev
Old Jun 26, 2014 | 07:56 PM
giz1978's Avatar
giz1978
low temp staes are for race use, if you want to keep temp down fit a a good oil cooler with themostate
i has been a god send on wifes rally car
Old Jun 26, 2014 | 08:44 PM
alcazar's Avatar
alcazar
Stick to OEM rads and thermostats. They work well...why waste money?
Old Jun 26, 2014 | 09:36 PM
jazzyjembreaze's Avatar
jazzyjembreaze
All good advise above
Nothing wrong with OEM
Old Jun 26, 2014 | 09:38 PM
wrxmargy's Avatar
wrxmargy
thanks alot guys, Never fail to get good info round here still going to get a mishimoto rad tho, any thoughts on this ? the weld quality looks good n it prettys up the bay abit
Old Jun 26, 2014 | 09:49 PM
wrxmargy's Avatar
wrxmargy
Originally Posted by mickywrx
160 degree!?
160 degrees fahrenheit not celsius, Ill remember the F next time lol
Old Jun 27, 2014 | 12:25 AM
rob84's Avatar
rob84
I have a mishimoto X line rad in my hatch as the oem **** thin thing was useless, a good hard thrashing and the water temps rose quite sharp to over 90c fitted the new rad and a high flow 78c stat and all is good.
Old Jun 27, 2014 | 08:34 AM
53's Avatar
53
Unless it's tracked go oem or Zerosports
Old Jun 27, 2014 | 04:50 PM
wrxmargy's Avatar
wrxmargy
Thanks matey
Old Jun 27, 2014 | 04:53 PM
wrxmargy's Avatar
wrxmargy
Thanks mate ill check out the zerosports
Old Jun 27, 2014 | 05:18 PM
53's Avatar
53
Zerosports is a 71dg stat and works really well. On my 2.5 it cruised at 78-84 and idles after hot runs a 88-92 peaking at 93 full boost on track
The Cosworth one I have now I bought for track use only and is too cold for road really on a year round basis. It cruises at 74-80 and with the eom oil cooler doesn't get a great deal hotter ideal for track but not on an everyday car
I run the Zerosports on the classic I have as well and I've never had one fail or a system that's got too hot. The benefit of a stat like a Zerosports as well is that should they fail they fail in the open position. OEM stats fail closed. This is an added safety benefit with the worst that can happen is a cold system, preferable to a cooked one
Old Jun 27, 2014 | 07:48 PM
mickywrx's Avatar
mickywrx
Post
That happened to mine, it's not ideal.
Old Jun 28, 2014 | 02:46 PM
wrxmargy's Avatar
wrxmargy
cheers mate, the failing in the open position is what made me think about getting a different one, just sells its self with a safety feature like that really
Old Jun 28, 2014 | 02:51 PM
Gambit's Avatar
Gambit
What is the oem stat rated at in comparison to zerosports 71degree?
Old Jun 28, 2014 | 04:36 PM
little'un's Avatar
little'un
Standard Turbo Thermostat is 78 degrees Celcius
27
Nov 4, 2021 07:12 PM
Abx
Jan 9, 2016 05:42 PM
FuZzBoM
16
Oct 4, 2015 09:49 PM
Brzoza
1
Oct 2, 2015 05:26 PM
Brett-wv14
Sep 29, 2015 01:46 PM
