S-Drive, Traction Control & Cruise Control Fault Lights!
Old Jul 14, 2013 | 02:52 PM
LiamWR1's Avatar
LiamWR1
Question S-Drive, Traction Control & Cruise Control Fault Lights!
I've just taken my 08 STi Hatch out this morning and noticed that after 100 yards the dash lights were not right...
The cruise control was flashing, as was the S-drive light (neither would switch off or over from their controls) and the same from the traction control, it showed off and as with the other two would change?
I VERY carefully took it home and looked through the manual, but no real clues as to why this was such.
Any ideas or suggestions appreciated.
Cheers, Liam
Old Jul 14, 2013 | 02:56 PM
rob84's Avatar
rob84
When the engine goes into limp home mode it defaults the Si-drive function to Sports mode and knocks out the cruise control and VDC assistance, you need to get the fault code read/fixed and the ecu memory cleared before it will resume normal business, or 5 stop starts if the issue has been fixed.
Old Jul 14, 2013 | 03:02 PM
LiamWR1's Avatar
LiamWR1
Cheers Rob, Sounds like a trip to the dealers then to make us whatever has caused it is sorted, when you say 5 stop/starts do you mean literally starting the engine 5 times would clear it!
Cheers, Liam
Old Jul 14, 2013 | 03:06 PM
rob84's Avatar
rob84
yes literally 5 stop starts of the engine.
I've got a little tip here, I was trying to make a video but not enough hands lol.
place your left hand on the light stalk, place your keys in the ignition
Turn the key to the 2nd position and quickly press the trip button 4 times then switch the headlights on, trip button 4 times, headlights off, trip button 4 times, headlights on trip button 4 times, this will then display the fault code on the dash board. but you have to be very quick in doing all of the above, on the fault code a single long press will remove the code.
Old Jul 14, 2013 | 06:00 PM
rob84's Avatar
rob84
Try this mate, Not the best guide I've ever done but not bad for a first attempt lol
Old Jul 14, 2013 | 09:44 PM
LiamWR1's Avatar
LiamWR1
Cheers for that Rob, it worked and threw up P1410, C0042, 71 and 76...
Great video as well.....
Old Jul 14, 2013 | 10:18 PM
T5NYW's Avatar
T5NYW
25 Year Member
From: MY99UK-MY02STi-MY99Type R-MY06 T20-MY11 340R-MY05 TYPE25
Rob very handy
Old Jul 14, 2013 | 10:41 PM
rob84's Avatar
rob84
P1410 - Secondary air injection system switching valve stuck open is causing the cel code..
The following 3 are spurious codes which never been cleared from factory, they most display these..
c0042 Is a power supply voltage
c0071 steering angle sensor
c0076 Clutch pedal switch
Old Jul 14, 2013 | 10:43 PM
rob84's Avatar
rob84
Originally Posted by T5NYW
Rob very handy
Just a handy piece of info to know if you ever need to ring the dealer to fix
Old Jul 13, 2014 | 11:25 AM
sniffmydiff's Avatar
sniffmydiff
South Wales Scoobys
These are the same warning lights I had on yesterday, I started the new thread in technical.
The lights have gone off and the car seems fine now.
I did the code test and it shows the following -
P_ _ _ _ on trip A , Trip B just shows a P then back onto trip A I had the following,
C 0042 then C 0071 then C0047
Great tip on the video Rob
Also my doors are still not locking remotely, if I leave car unlocked , take keys in house , go back out to car after a minute and it hasn't locked itself, it used to work ok , is there a reset for this ?
Thanks ,
Geraint.
Old Mar 16, 2017 | 08:10 AM
Matty81's Avatar
Matty81
Is this the same for a 2008 wrx mate ?
Old Mar 16, 2017 | 08:16 AM
The Trooper 1815's Avatar
The Trooper 1815
18 June 1815 - Waterloo
Some one is tired. Only three years late.
Old Mar 16, 2017 | 08:21 AM
Matty81's Avatar
Matty81
Why would I be tired ? I'm trying to find a fault code and was asking if that would be the same for my car. Whole point of the forum isn't it. If your not gonna say anything constructive don't bother.
Old Mar 16, 2017 | 11:11 PM
Vxr2010's Avatar
Vxr2010
10 Year Member
the clip is a good little trick , it is also possible to get code readers on ebay for around 15£ and you can also delete codes using them too
Old Mar 16, 2017 | 11:20 PM
Matty81's Avatar
Matty81
The above worked in the end mate after trying it 3 or 4 times. Would of never knew you could do that if I hadn't come along this thread mate.
Old Jun 15, 2019 | 08:35 AM
mr_maj1k's Avatar
mr_maj1k
Default Cruise control light flashing
what was the initial problem Liam and did it reoccur
Old Jun 15, 2019 | 10:22 AM
Don Clark's Avatar
Don Clark
Posts # 6 & 8
27
Nov 4, 2021 07:12 PM
Abx
Jan 9, 2016 05:42 PM
