Newbie in South Wales
Old May 3, 2010 | 04:18 AM
Jimbob's Avatar
Jimbob
Well progress to be reported.
Now have an engine. From on here Mattybr5.
Heres the spec.
Version 1 to 4 forged engine done around 5500miles since built.. Including turbo/inlet/rcm pullies/clutch/fly
all parts brought by prev owner from rcm manly built using semi closed deck block 0.5overs size omega pistons arrow rods acl bearing rcm modded oil pump up rated thermo stat ect cosmetic head gaskets unsure on specs ov heads tho sorry was mapped on a s/r 55 turbo on apexi ecu by alan jeffary at engine tuner at 375.6bhp runs very well and pulls like a train many extra that iv not listed like new coil packs
Oh also got these.
Old May 3, 2010 | 08:17 AM
Useless's Avatar
Useless
Good progress James!
The 4 pots are a must on earlier cars as the standard brakes are shocking!!
Old May 3, 2010 | 08:30 AM
R1CH D's Avatar
R1CH D
Spot on fella Mattybr5 is a genuine guy to buy from, done a couple sales with him
Old May 3, 2010 | 08:45 AM
stibex's Avatar
stibex
hi welcome a long a good place for oparts is awsome imports m8 has seas and every think u would need just over seven bridge really
Old May 3, 2010 | 07:38 PM
Jimbob's Avatar
Jimbob
Cheers fella.
Yeah not even driven i and was gonna upgrade my brakes!!
Yeah top guy. Will be able to give you a run for your money soon lol.
Cool, will have a look around.
My list is so far shorter.
FSE, FMIC, Remap, Interior, paint.
Old May 4, 2010 | 09:19 PM
stedee's Avatar
stedee
fpr and parallel fuel rail mod, you want to look after that engine.
ive got a forged block ready to go in but wont put it in till ive got the fuel rail mod done
Old May 4, 2010 | 09:46 PM
L55 REP's Avatar
L55 REP
well done fella good progress. the seats wouldnt be any good for you
get a nice set of Brides
if you want to get shot of your old engine id give you £100 for it
need a turbo/turbo oil feed pipes camshaft pulley and odds and sods
let me know asap though please fella i got to get sumut sorted tomorrow
Old May 4, 2010 | 10:27 PM
Jimbob's Avatar
Jimbob
You got any links for those??
Erm was gonna use mine as spares incase anything goes Pete Tong with mine.
SO dunno, mind you don`t even know how to remove the sodding thing yet!! lol
Old May 4, 2010 | 10:45 PM
L55 REP's Avatar
L55 REP
text you back fella
Old May 5, 2010 | 03:07 AM
Jimbob's Avatar
Jimbob
Nicked from somewhere else.
Originally Posted by MYR58U (Type-RA.co.uk)
Re: Parallel Fuel Rail Mod
You can do it yourself very easily. There is a more detailed description in my thread on my car, but basically you need to pull the intake manifold off, remove the old fuel lines and rails, and from there buy:
What:
- 8mm (5/16") fuel hose (I bought 5m to have some spare)
- x2 fuel T-pieces to suit above hose
- x15 hose clamps - put 1 on every join. You'll have some spare, which is always good.
- x2 PASSENGER side fuel rails (no fuel pressure regulator on passenger rails)
- x1 aftermarket adjustable fuel pressure regulator (with gauge). I found Sard to be the best and most reliable.
- x1 set of spare under-manifold fuel lines to cut up PLUS your old ones
Why:
To ensure equal fuel flow to each cylinder, you need to ensure pressure is kept equal in both rails. This is achieved using precisely identical lengths of hose for the feed and the return. What you want is one piece of hose going from the filter to a T-piece, which splits in 2 and runs to the fuel rails. Fuel goes through the rails, out the back and then you have 2 pieces of fuel hose (identical to the feed side) taking it back to another T-piece, which then takes it to your fuel pressure regulator mounted somewhere else in the engine bay (from the reg. it will then go down the return line to the tank).
How:
Get the elbows (which join the fuel rails) cut off your old fuel lines and have the ends swaged (so the hose doesn't pop off/leak. This is really easy and should cost you almost nothing.
Then, get the measuring tape out and measure the distance from the OUTLET of your fuel filter to the middle of the engine (where your T-piece splitter will be). Your return line to the fuel pressure regulator needs to be the same length as this feed line.
The lines going from each T-piece across to each rail should be the same length and i've found 300mm to be a good size as it is a bit longer than required (and therefore fits around the various pumps/wiring/etc under the intake manifold). Remember, you need to be precise when measuring to ensure equal flow.
Once you've trialled how it all goes together, fit it up, mount the fuel pressure regulator and adjust the pressure (for 380s it should be around 38psi, 440s will require 45psi I think) and tidy up the vacuum lines, etc.
Pic of mine.
Old May 10, 2010 | 02:44 AM
Jimbob's Avatar
Jimbob
Got a stop gap for my SHOCKING PAINT!!
Well she needs a re-spray, BUT before I spend a fair wedge on paint (will go Sonic Blue when sprayed). I`m gonna get her running and iron out potential problems, then uprate the injectors and get a FMIC, then get her mapped.
So as you can see MANY things can go wrong in the mean time, so decided to distract the attention away from the paint by doing this.
Full Subaru Vinyl kit, in Dark yellow and light blue shadow, full sponsor pack, and also a matching boot vinyl, seeing as mine has no badges at all!!
This WON`T be permanent, but will be till shes running 100% sweet and ironed out all the niggles she`ll no doubt have.
Then when sorted she`ll get the paint she`ll deserve.
Old May 10, 2010 | 10:59 AM
evil.soup's Avatar
evil.soup
Welcome mate!
Really love what you are doing with the car, its great when someone rescues a car from the scrappy, well done
Old May 10, 2010 | 06:50 PM
Jimbob's Avatar
Jimbob
Originally Posted by evil.soup
Welcome mate!
Cheers buddy. Yeah so many nice older cars have fallen foul of this scrappage scheme too, when the opportunity came up to have the car I had to. Was only going to put a £500 engine in tbh, but when my Vectra blew a piston then threw a rod and holed both sides on the case, I decided to sell all of the many tuning mods, and upgraded parts for my Scooby. Still have bits to sell like a nice set of Recaro seats, front rear and door cards, shame they don`t fit the Scoob!
Just need a hand to remove the engine and fit the new one (I`ve no clue lol).
Old May 10, 2010 | 07:53 PM
redwards's Avatar
redwards
When are you thinking of swapping the engine out?
Old May 10, 2010 | 08:09 PM
Jimbob's Avatar
Jimbob
Sometime this week hopefully for the time being I`m free weekdays, but busy weekends. Can`t do it on the weekend as I`m an Area Rep on VVOC (Vauxhall Vectra Owners Club), and I`ve organised a 2 day fishing comp in Newport on the weekend (something different to do ).
So sometime this or next week.
Can move the car as I`ve a towing A-Frame and a Jeep.
Old May 10, 2010 | 08:18 PM
redwards's Avatar
redwards
I can't help this week or next, but should be free after that. I have an engine swap for a peugeot diesel taking up space at the moment. This is hopefully going to be sorted Sunday, depending on the owners ability to get his ar$e out of bed.
Old May 11, 2010 | 12:33 AM
Jimbob's Avatar
Jimbob
No worries, shall be attempting this week. lol.
BUT any help would be greatly appreciated.
Old May 11, 2010 | 05:12 PM
Jimbob's Avatar
Jimbob
Been buying AGAIN.
This is more Insurance and peace of mind, more than anything else.
And I`m not fussed if its ott or whatever as long as it bring my insurance down lol.
Tracker Horizon.
TRACKER Horizon operates using TRACKER’S proven very high frequency (VHF) technology as with TRACKER Retrieve, but in the event of theft where the vehicle is moved without the ignition turned on, the motion sensor will alert TRACKER who will in turn notify YOU.
Tracker Horizon has all the functionality of TRACKER Monitor with the added benefit of Global Positioning System (GPS).
The benefit of this dual technology allows:
• GPS positioning information to locate the vehicle on computer based maps
• Information on the vehicle’s location and direction to be relayed to appropriate police force
• Should the vehicle at anytime lose the GPS positioning, then TRACKER’S proven very high frequency technology will be used by the police to track the stolen vehicle to its exact location, even if it’s hidden in a container or underground car park.
• Once the vehicle is located, TRACKER will arrange for a uniformed guard to stay with the vehicle until the recovery company arrive to pick it up and return it to you.
Activate On confirmation of the theft and receipt of your police crime reference number, TRACKER will activate the unit, which will begin to emit a silent signal allowing the police to track the vehicle to its exact location.
Track Using VHF and GPS tracking technology, the police can begin to track the stolen vehicle
Locate All of the UK’s police forces as well as the French Gendarmerie and Spanish Guardia Civil and Policia Local operate the TRACKER system to quickly track and locate the stolen vehicle.
Secure Once located, TRACKER will send a uniformed guard to wait with the vehicle. This service is only available in mainland Great Britain.
Recover TRACKER will arrange for a recovery company to collect and return your vehicle to you. This service is only available in mainland Great Britain.
Old May 11, 2010 | 10:26 PM
Jimbob's Avatar
Jimbob
Also had these through the post, one was wrong so they sending me a replacement.
Old May 15, 2010 | 08:57 PM
G-string's Avatar
G-string
Cool
Looks like you got lots planned mate, should be very nice when totaly finished
Old May 16, 2010 | 11:32 PM
Jimbob's Avatar
Jimbob
Yeah should be fingers crossed. Well as long as I can get a decent cheap paint job, as the standard paint is SHOCKING.
Old May 24, 2010 | 09:26 PM
Jimbob's Avatar
Jimbob
Right been making some progress, basically pulled my finger out of my ****!! lol.
Bascially these pics are to help remind me where things go (as I`ve no clue lol).
Dropped the bonnet down off the daft ally blocks so looks a lot better.
One is an indicator bulb any idea what the other cable is for?? Fogs??
Missing bit on the gearbox.
Wheres the Earth cable usually attatch??
No vacuum hose to the FPR, no idea where it is either.
No vacuum hose to/from the turbo. Is it the Blue one in the pic??
Old May 24, 2010 | 10:36 PM
Jimbob's Avatar
Jimbob
Well forgot to take a photo of the air filter, which in my mind is a good way of seeing if the car has been looked after or not.
Well you tell me lol.
Front nearest engine looks all fine and dandy.
Intake nearest outside is another matter.
Better order a new one, and a fuel filter if the air filter is that caked in shiiite.
Old May 31, 2010 | 05:01 PM
  #54
Jimbob's Avatar
Jimbob
Update.
Old May 31, 2010 | 05:02 PM
  #55
Jimbob's Avatar
Jimbob
Update.
FINALLY figured it out lol.
Old Jun 1, 2010 | 02:26 AM
  #56
Jimbob's Avatar
Jimbob
Old Jun 3, 2010 | 10:08 PM
  #57
Jimbob's Avatar
Jimbob
Tada!!
Old Jun 3, 2010 | 10:40 PM
  #58
THE DOCTOR's Avatar
THE DOCTOR
nice one fella, if you still want a workshop manual I will have cd's at the meet on Sunday
Old Jun 3, 2010 | 10:41 PM
  #59
redwards's Avatar
redwards
Looking good You should be on the road in no time.
Old Jun 3, 2010 | 10:48 PM
  #60
Jimbob's Avatar
Jimbob
Doubt I`ll make the meet fella, this has a lot of bits left to do (hopefully NOT engine related!!).
But DEFFO want one.
Yeah hopefully.
Could someone take a pic of the vacuum hoses that supply the turbo/manual bleed valve/and those two large vacuum pipes??
I know the central one of the 3 on top of inlet manifold, runs the FPR vacuum. But wanna make sure I connect the turbo vacuum feeds etc correctly, also will turn the manual boost controller so that its standard boost, as I wanna get it set boggo, then when I have a few other mods ready fit and get mapped.
