The rear pin sits neat inside caliper with the tip point slightly protruding./ if your pin keeps working it’s way out the spring compression plate may be buckled. Even if your pad hole diameter was larger than norm the plate is designed to give tension against the pad pin so it can’t move .. strip it back & instal all items again
