Newage Power steering pump set up.
Old Oct 16, 2017 | 11:00 PM
Arch's Avatar
Arch
Default Newage Power steering pump set up.
I have my power steering pump and reservoir available. The bracket has been lightened by removing the alternator adjustment pivot as I had reversed my inlet and it wasn't needed. This will come with the pump, the bracket, the reservoirs and pipework and two sets of pressure feed pipes with banjo fittings for the pump, the pump also has the banjo bolt and copper washers. £85 including delivery buyer to pay any paypal fees.
Old Oct 24, 2017 | 09:16 AM
Arch's Avatar
Arch
BTTT
Old Nov 1, 2017 | 11:45 PM
Arch's Avatar
Arch
SOLD
Old Nov 6, 2017 | 12:56 PM
imprezagaz's Avatar
imprezagaz
did You have these pipes made or was they a kit?
Old Nov 6, 2017 | 02:00 PM
Arch's Avatar
Arch
The pipes are standard except for the pressure feed from the pump to the rack. I had them moddedby pirtek to add the length of hose with the banjo fitting for the pump. It's critical this is done properly as the pressures here are high.
Old Nov 6, 2017 | 02:04 PM
imprezagaz's Avatar
imprezagaz
thanks. Il look into it
Old Nov 6, 2017 | 03:01 PM
Arch's Avatar
Arch
no problem
