Full Cars Breaking For Spares This forum contains details of cars being broken for spares by our Authorised Advertisers ONLY.
BLOBEYE UK STI WIDE TRACK BREAKING 32J (6spd dccd/ej207/bc's/re070/tsl/vf35/brembo+)
Old Jun 12, 2017 | 08:31 AM
Mattybr5@MB Developments's Avatar
Sponsor
Default BLOBEYE UK STI WIDE TRACK BREAKING 32J (6spd dccd/ej207/bc's/re070/tsl/vf35/brembo+)
ok we have another nice 05 blobeye wide track sti in 32j black in for breaking all in excellent working order very well looked after..all parts will be removed later on this week so please check delivery before buying please
all parts are based on collection delivery can be arranged at extra cost please ask
collection and inspection welcome from
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
call or txt for quicker reply 07785942237
colour code 32j black
ENGINE AND RUNNING GEAR
ej207 sti semi closed deck avcs heads long engine £sold
dccd 6 speed gearbox £sold
114pcd wide track male ended heavy duty sti front drive shafts £sold
114pcd wide track r180 larger rear drive shafts £sold
114pcd wide track sti full hubs £sold
6 speed fly wheel no juddering etc. £40
6 speed starter motor £45
vf35 turbo charger £sold
sti larger tmic £sold
sti large under tray good con £60
Aftermarket dump valve £sold
550cc pink injector’s £sold
sti water spray bottle with switch and jet in boot mounted £40
sti red crinkle inlet tgv delete inlet £sold
newage sti avcs engine wiring loom excellent con uncut or modded at all £60
Full dccd car wiring loom uncut or modded minus small engine loom £12
sti ecu with key set and barrel/door/boot locks with sender unit £150complete
sti turbo inlet pipe excellent con un ripped ect £30
sti standard headers great upgrade great addition to wrx items also inc non catted sti uppipe £60
oem catted sti down pipe £sold
cat back exhaust system £sold
Walbro 255 lph fuel pump excellent working order great upgrade part £30 or £40 with sender unit complete
oem air box good con £20
2 port boost solenoid £20
Maf sensor excellent working order genuine part £45
Front lambda sensor genuine part excellent working order £60
Rear lambda sensor excellent working order £40
Map sensor excellent working order £30
Throttle body with tps fitted no idle control valve inc great working order £25
Idle control excellent working order £30
Crank sensor excellent working order genuine part £25
Front cam sensor excellent working order genuine part £25
plastic header tank £sold
3 pin alternator excellent working order £30
Air con pump excellent working order £25
Air con condenser rad good con £25
Radiator with twin fans good con no leaks etc £45
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
Sti billet Battery claim and threaded bars £25
WHEELS/BRAKES/SUSPENTION
enkei17x8j 114pcd alloys wheels £sold
gold brembo front brakes £sold
gold brembo rear brakes £sold
Bc br coilover suspension set up £sold
Pink ended front upper strut brace£sold
6 speed gearbox cradle good con £25
wide track revised Front sub frame good con £45
Front lower u brace good con and solid £sold
revised wide track Rear sub frame good con £45
wide track alloy rear trailing arms good con with good bushes £100set
wide track revised Steering rack steering rack £45
Pas steering pump £sold
Pas pipe with remote bottle and cooler £30
Brake master cylinder good working order £20
Clutch master cylinder good working order £20
114pcd wide track space saver good con £25
ABS module perfect working order £45
EXTERIOR BODY WORK
sti front bumper £sold
wide track rear bumper with arch extensions £sold
blobeye alloy bonnet £sold
hella horn set £sold
blobeye uk sti headlights de tangoed and black mod £sold
blobeye rear lights £sold
blobeye sti wings £sold
sti twisted side skirts £sold
sti rear hi level spoiler with perrin wing stiffis £sold
sti boot lid good straight condition with good paint and no rust showing £80 (NO BOOT LOCK FITTED)
wide track aero under trays both sides good con £30pair
4x doors all complete with glass and some internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Rear heated screen good con £45
Window rubbers all good con both sides £30pair
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
Jvc touch screen double din touch screen app head unit £sold
Prosport evo gauge set up £sold
wide track sti revised centre console conversion £sold
wide track all black sti steering wheel £sold
revised wide track sti seats £sold
wide track revised sti door cards £sold
wide track door switches perfect working order £40set
Chrome sti door handles to 01 onward great wrx upgrade £25set
sti blue interior carpet £sold
revised sti 6 speed gear **** very good con £40
Pedal sets great con great classic upgrade £25
dccd buttons £15 each
dccd sti blue clock set excellent working order low mileage £120
newage dash top good con £30
newage glove box section good con £15
newage drivers side lower dash good con £10
Boot carpet £sold
Boot side liners £sold
Spare wooden wheel cover £20
oem jack and wheel brace in Subaru bag £20
a/b/c pillars plastics all good con £poa
alarm sensor from a pillars £10pair
Anything i may have missed please ask im sure we will have it
Old Jun 12, 2017 | 09:54 AM
Irontusk86's Avatar
Irontusk86
I take it the discs for the brembos are 5x114.3?
Here i am trying not to splash out on a brembo upgrade after refurbing some STI wheels to fit over them and you post up a whole 32J STI front end!
Damn you!
Old Jun 12, 2017 | 10:01 AM
domino46's Avatar
domino46
will take the idle control valve , pm me payment details please
Old Jun 12, 2017 | 08:35 PM
housty-wrx's Avatar
housty-wrx
Hi im needing a front subframe for my blob wrx does the wide track blob sti fit blob wrx? If not have you got any good condition subframes for a blob wrx?
Old Jun 13, 2017 | 08:49 AM
Sponsor
Iron pm replied thank you
Domino yes no problem we can sortthat for you
Houston all depends on your year car pm me and we can sort the correct one out for you
Old Jun 14, 2017 | 10:25 PM
XTY's Avatar
XTY
Default How much to post the hella horn? TQ3 post code
How much to post hella horn plz
Old Jun 17, 2017 | 07:26 AM
sivo's Avatar
sivo
Old Jun 19, 2017 | 08:10 AM
Sponsor
XYT Sorry they have now sold sorry
all pm's replied and listed updated with new pics added
Old Jul 8, 2017 | 12:41 AM
Lefty1's Avatar
Lefty1
Hi how much for the rear lights and steering wheel delivered?
Old Jul 10, 2017 | 08:06 PM
Sponsor
sorry I'm afraid both have already sold now I'm afraid we should have more back in soon hopefully
all pm's replied
Old Jul 17, 2017 | 07:33 AM
Sponsor
LIST UPDATED ALL SOLD ITEMS LISTED
Old Jul 18, 2017 | 07:04 PM
RAPID RABBIT's Avatar
RAPID RABBIT
Hi,
Have you got an exhaust downpipe bracket from a six speed. Like in this pic cheers
Old Jul 19, 2017 | 07:17 AM
Sponsor
Sorry we don't they go on the gearbox when we sell them sorry
Old Jul 19, 2017 | 09:32 AM
2001_UK300's Avatar
2001_UK300
Can I just ask why you decided to break this? Looks in pretty good condition and like you mentioned it was a good runner..........
Old Jul 19, 2017 | 11:42 PM
Sponsor
Your asking a Subaru breaker why we are breaking a Subaru??no one wants bits off rotten non running beat up cars we break the best cars available it keeps our customers very happy
Old Jul 20, 2017 | 08:54 AM
2001_UK300's Avatar
2001_UK300
That's fair enough, I work for a breakers yard and sometimes we sell vehicles like this that's why I asked, just looks a little too good to break lol
But yeah like you say no one wants crap parts so, probably make more money as breakers some times as well
Old Jul 20, 2017 | 01:12 PM
Sponsor
breaking is our game we sell the odd car but have a demand for the parts so break more than we sell
Old Jul 21, 2017 | 11:22 PM
360ste's Avatar
360ste
Hi Matt, I am after the rear 12 inches of rust free outer sill, both sides off a newage. How much would this be, collect?
Cheers Steve
Old Jul 24, 2017 | 02:01 PM
Sponsor
hi steve I'm afraid I don t have a shell in stock were willing to cut out at the moment maybe next week but completely rust free is getting a rare thing now with them
Old Jul 24, 2017 | 08:40 PM
360ste's Avatar
360ste
Cheers Matt, I thought mine was low on rust until I jacked it up!! LOL
If you do get one please let me know.
Old Jul 27, 2017 | 08:02 AM
blackandgold scooby's Avatar
blackandgold scooby
Can i grab the passengers wing mirror glass and air con rad please
Old Jul 28, 2017 | 01:50 PM
Sponsor
Yes we can sort these pm me we can sort them out thank you
All pm's replied
