Hawkeye WRX turbo upgrade?
Old Jan 15, 2017 | 10:55 PM
captainlip's Avatar
captainlip
Default Hawkeye WRX turbo upgrade?
So my new 2.5 WRX is going in for a major srtip down in a couple of weeks, new heads new stage 1 clutch, oil filter, coolant flush, NKG plugs, timing belt, waterpump, walbro fuel pump, full decat. and so on.
After this it will need a remap, but im unsure to hold off on turbo upgrade and just remap for now until I know the car is all running well.
I'm looking with this little project to run 350bhp which is the safe limit for these 5spd gearboxes apparently.
what turbos can I just slap on and remap that will give me a wide power band through the revs. suggested VF43 are there any others to look out for?
Am I tempting fate to consider a bigger turbo than a vf43 and push for the 380/400bhp and if so what turbo to achieve this?
Old Jan 15, 2017 | 11:08 PM
sssssteeeee's Avatar
sssssteeeee
VF34 roller bearing mapped well will get u approx. 350 ,350 swapped mine for this mapped by bob rawle good reliable unit with excellent low down throttle response, with some other parts as well . 3 port , rcm fuel pump, fmic, fpr , and of course alcatek ecu, incase I think of possible stroker engine , and indeed ppg gear set. but im more than happy with things as they sit. currently concentrating on other mods.
Old Jan 16, 2017 | 11:40 AM
Ste333's Avatar
Ste333
Most turbos are straight bolt on in standard position. You just need the accompanying mods. For 380-400. Consider something from the MD range - MD321H?
Or a SC38 or SC42? Or a slightly more old school TD05 variant - 18G or 20G.
Old Jan 16, 2017 | 02:48 PM
captainlip's Avatar
captainlip
The injectors on the Hawkeye are the same as the STI
Old Jan 16, 2017 | 03:20 PM
Ste333's Avatar
Ste333
you're right - apologies. I didn't realise that Hawk WRX and STI's shared the same injectors.
Old Jan 16, 2017 | 03:38 PM
Don't get a bigger turbo than your power needs, it will just give you more lag and worse driveability. Stick with a turbo rated for 350bhp like the VF34, VF35, VF43, VF48 or TD05-18G ported.
All of these will work well on the 2.5 engine and bolt straight on. The VF43 and VF48 are designed to work with the 2.5 engine so are a better choice IMO.
Old Jan 16, 2017 | 04:17 PM
captainlip's Avatar
captainlip
but if the end game is 400bhp which then, and its 400 a no go without changing the gearbox. thanks for advice
Old Jan 16, 2017 | 04:20 PM
You'll need to upgrade most of the parts to STI parts, like gearbox, diff, shafts, brakes etc etc.
Why not either start with an STI if your new goal is 400bhp or stick to a power level (350bhp) which is realistically as much as you can do to the WRX without blowing everything up.
Chances are that you'll get ringland failure or head gasket failure on the 2.5 anyhow as upgrading and pushing the engine will only promote these known failure issues.
Budget £3.5k for a forged rebuilt.
I had a 2.5 hawk WRX at 334/381 and it was an absolute pleasure to drive daily on the road.
Old Jan 16, 2017 | 06:42 PM
captainlip's Avatar
captainlip
Yeah its sat outside waiting for a new head now haha, plus everything else in post 1. suppose Ill have to live with 350 so many turbos to choose from its a minefield yet only the vf35s seem to be for sale.
Old Jan 16, 2017 | 10:11 PM
Matty81's Avatar
Matty81
Did you forge the engine to achieve those figures mate ? Or did you just upgrade it without forging it ?.
Old Jan 17, 2017 | 10:22 AM
me?
Old Jan 17, 2017 | 10:32 AM
On-the-bog's Avatar
On-the-bog
Hawk wrx box will be fine at 400, they are alot more robust than early ones. But that said i wouldn't want to push the wrx engine anywhere near that without sorting the rods and pistons
Old Jan 17, 2017 | 10:48 AM
^^^ completely agree. Good advice.
+ Head gaskets.
Old Jan 17, 2017 | 11:08 AM
The Trooper 1815's Avatar
The Trooper 1815
18 June 1815 - Waterloo
Really?
Old Jan 17, 2017 | 11:16 AM
On-the-bog's Avatar
On-the-bog
Originally Posted by The Trooper 1815
Really?
yep
Matty81's Avatar
Matty81
Yes mate
Old Jan 17, 2017 | 11:21 AM
Yep. The hawk 5 speed boxes have slightly larger gear teeth and can take more power and torque than the earlier newage 5 speed boxes. Someone on here a long time back took one apart and compared it to an older box.
Plus there are a lot of people running hawk WRX's with higher power levels with no issues at all on boxes.
Old Jan 17, 2017 | 11:22 AM
scooby2.5maz's Avatar
scooby2.5maz
Really?
Have to say I agree with that but a lot depends on driving style etc etc. I've ran 400 bhp from my first hawk wrx and had no issues. I think Martin Jeffrey ( engine tuner ) ran 500 bhp from an earlier post a while ago .
I'm at 390/390 on rb5 5 speed although that's running a 5 speed VBAAA so maybe it's a bit tougher . (P1 box )
Maz
Old Jan 17, 2017 | 11:28 AM
Matty81's Avatar
Matty81
That's interesting to hear
Old Jan 17, 2017 | 03:06 PM
Matty81's Avatar
Matty81
Can anyone tell me what turbo could be replaced with my current td04 on my hatch 2008 wrx ?. I've heard that I don't have alot of options turbo wise.
Old Jan 17, 2017 | 03:26 PM
All the turbo's quoted in this thread bolt straight on to your 08 WRX.
Have a look at the turbo's in my post number 6.
Old Jan 17, 2017 | 03:29 PM
Matty81's Avatar
Matty81
That's interesting.
ive just spoke to Richard at fb tuning and he said that other turbos wouldn't mate.
Old Jan 17, 2017 | 03:45 PM
Ah yes, you could be right actually. Doesn't the turbo bolt to the intercooler in a different way? VF52?
Old Jan 17, 2017 | 03:52 PM
Matty81's Avatar
Matty81
Yeah, he said that the turbo flange is different to other wrx's. I was thinking vf52. He said that I could replace the billet wheel but I'm not sure at what cost. Obvs a new bigger turbo maybe a better option and I think that the vf52 fits because the us version wrx are fitted with these apparently. basically I told him that I want around 300hp from the car but he said that I couldn't achieve that with the td04 without the billet wheel being changed.
Old Jan 17, 2017 | 04:09 PM
captainlip's Avatar
captainlip
having said that the box "could" take 400bhp is there a slightly more powerful turbo than the vf43, 34, and 35 that I could get closer to 400 with the mods in post 1.
scooby2.5maz
Vf 43 , vf48 . Td05 18g . Td05 20g btween 340 to 390 maybe with this lot .
Maz
Old Jan 17, 2017 | 04:13 PM
JGlanzaV's Avatar
JGlanzaV
If the headgaskets have gone then you will need to do the bearings too. They are liable to fail in short order after HG failure and you will end up rebuilding again
Old Jan 17, 2017 | 04:27 PM
By the sound of your rebuild, you are not fitting uprated pistons, head gaskets or head studs at the very least as part of a forged build? If not, 350bhp should still be your limit. You WILL blow the engine up again otherwise.
Just to give you an idea, a good forged engine build for a 2.5 engine that will handle 400bhp all day long will cost between £3.5-5k to do right at a reputable builder.
Old Jan 17, 2017 | 04:34 PM
ted bass's Avatar
ted bass
Running a vf34 with supporting mods on my 06 Hawk wrx, dyno print out was 331/330 but find it a bit laggy and don't spool up all that quick, hoping a harvey trick pipe and a tweak will help matters
Old Jan 17, 2017 | 04:38 PM
Matty81's Avatar
Matty81
I spoke to a guy from fb tuning mate and he said that the turbo flange on an 08 is different to previous wrx'. A vf52 maybe my only option. Only wanna push 300.
