ScoobyNet.com - Subaru Enthusiast Forum - View Single Post - WE ARE THE MSOC .. member & car profiles
View Single Post
Old 16 March 2011, 02:17 PM
rickya
rickya's Avatar
Ocupation: Serial Scoobynetter...oh yeah & Hotel Mngr!
car:JDM Ver9 Widetrack STI
Year: MY05
Colour: Crystal Grey
Bhp: 365 bhp / 355 ft/lbs
Mods: So far-
JDM Ver9 Sti Engine with Nitrided Crank etc
Std Twin Scroll VF36 Spec C Roller bearing Turbo
With Forge uprated 1.7 bar Actuator & 76mm Silicone turbo inlet hose
JDM 6 speed box with DDCD- Auto & Manual
Spec C fuel pump 245 l/ph with Anti Surge Kit
Sard Fuel Pressure Regulator
VTA breather system with 3 port baffled oil catch can, return to sump -Aeroquip ftngs
Prodrive 3 port boost solenoid
3" full Miltek exhaust system for track- 92db @ 5,000 rpm
(3" Fujitsubo Giken jap exit exhaust- 102 db @ 5,000 rpm)
APS 70mm CAIK with K&N cone filter with Cold Air feed from front fog cover
NGK PFRB7 one step colder plugs
JPerfomance 55mm Alloy Radiator with Silicone Hoses
Exedy Pink Racing 6speed Clutch & skimmed flywheel
ZeroSports under bonnet air diffuser
Zerosports 67deg colder thermostat
STI rear upper & front strut brace
CDF Racing Anti lift Kit
Whiteline uprated Steering rack bush kit mated to the JDM super quick rack
Hardrace Engine Mounts & stabiliser
Hardrace Shifter Bush kit
Tein Mono Flex Winding Master coilovers
Cusco front lower H-Brace
Hardrace Trailing Arms
Hardrace Adjustable Lateral Links
Super Pro Roll Centre Kit
Hardrace adjustable rear Drop Links
TFS adjustable front drop links
Whiteline front 24mm Anti Roll Bar
Whiteline rear 24mm adjustable Anti Roll Bar
Eibach camber bolts & Custom Alignment
Alcon ProR forged monoblock 6 pot brake calipers -front
Alcon ProR 365mm 2 piece floating brake discs -front
Pagid RS29 carbon ceramic brake pads -front
Custom front brake cooling ducts - (unfinished)
Braided brake lines with new OEM master cylinder
Brembo Sti Gold calipers with Ferrodo DS2500 pads - rear
Factory Xenons & detango
Facrory JDM Rear Tints
Sti front lip spoiler
Msport rear windscreen lip spoiler
Spec C rear diffuser
Carbon Bonnet Struts
Front bumper Alloy Mesh, badge delete
Custom front bumper satin black paint
Cobra Imola Pro Bucket seat 6.8kg & Omp Subframe
Momo (Saebelt) 3" four point harness
Depo Racing 4 in 1 Gauge in Autobahn 888 pod
Clifford G5 with Proximity sensors & Anti hijack
In car 1.5 litre fire extinguisher
Stebel Nautilus Compact air horn 139db
Pioneer DEH 4400BT headunit
JBL GTO 6528 6.5" front door speakers
Rays Prodrive forged monoblock GC0F 18x8 wheels 42mm offset - resprayed JDM Bronze
Rota Torques 18x8.5 wheels 42mm offset with Federal RSR 235/40/18 for Trackdays
Mapped by Racedynamix 365bhp / 355 ft/lbs
https://www.scoobynet.com/middlesex-...widetrack.html
[img]pics to follow[/img]
Previous Imprezas:
Ver6 Type R WRC LTD:
https://www.scoobynet.com/middlesex-...r-wrc-ltd.html
Litchfield Hawkeye Spec C
https://www.scoobynet.com/southern-e...ods-to-do.html
rickya is offline
