Parallel fuel rail kit
Old 01 April 2015, 01:16 PM
Townsend94
Townsend94's Avatar
Default Parallel fuel rail kit
Where's the best place I can get a parallel fuel rail kit for my version 2 gc8?
Old 01 April 2015, 01:32 PM
FMJ
FMJ's Avatar
IMO most places either over charge for these, or they are ebay kits using cheap parts. You obviously want a bit of quality when talking about high pressure fuel.
If you are handy with these sort of things it's not too hard to make the kit up yourself. You will need a couple of fuel rails (either new ali ones or chop up and modifiy stock ones), two t piece joiners, four or more 90 degree elbows (depending on how you run it), an fpr, a gauge and some good hose and clamps.
Tips:
Be careful which connectors you get. Most people use ali 6an connectors which are ideal but there are a lot of different style all of which hold the hose in different ways. Some are better then others. There is an ebay company called torques which are recommended and supply good stuff at good prices.
Make sure the FPR is AFTER the injectors on the return line.
Make sure if using braided hose that the hose doesn't touch anything else. It acts a a file and will cut through rubber hoses or wires, ever metal work due to engine vibrations.
Use a gauge to make sure that you keep stock pressure.
When fitting new rails use new injector o rings and rail seals as a leaky injector can kill the engine or a leaky rail can set fire to an engine.
Don't have the hose bend too much as it puts pressure on the fittings and the hose walls. If it has a tight bend use another joiner of the right angle.
Old 01 April 2015, 01:50 PM
Sarg400
Sarg400's Avatar
Try cdf racing mate
Old 01 April 2015, 02:16 PM
cookstar
cookstar's Avatar
I got my kit from CDF, most other required parts from Lateral Performance.
Old 01 April 2015, 02:26 PM
banny sti
banny sti's Avatar
Alyn AS Performance or CDF
Old 01 April 2015, 04:43 PM
IainMilford
Support Scoobynet!
IainMilford's Avatar
One tip is to use the same manufacturer for the hose and fittings, as been stated can vary slightly from one to another. I have rcm rails and a fuel lab fpr, all hose and fittings supplied by torques
Pro-Line Motorsport
Car Parts For Sale
48
21 July 2017 09:50 PM
28 December 2015 11:07 PM
18 November 2015 07:03 AM
IAN WR1
8
28 September 2015 08:14 PM
Quick Reply: Parallel fuel rail kit
