Brake Overhaul
on
Brake Overhaul
So i have had some AP Racing CP6600 on my legacy for a few years and they finally showing their age and need a refurb, I need new pads and also need to replace the disc section of my two piece rotors as they are well worn and are warped so currently its not a pleasant braking experience.
So for fast road use in a daily driver what would be a good option of pads to got for these days? I currently have EBC yellowstuff that aren't that great for my setup
Calipers will need to be stripped down and seals and wear plates fixed too. Is it a big job to refurbish the calipers yourself? Any specialist tools required? Only other option would be to send them to someone to get refurbished but options are limited in Ireland so i would probably need to send them to UK
on
Contact Godspeed or AS Performance (both members here) about having a refurb carried out, or, if you're handy and have decent tools I'm sure they'd sell you the required parts to do the job.
THE braking specialist
HI
The calipers are fairly easy to do if you know what you're doing , you don't need any specialist tools to do them.
Its very rare to have to change the pistons in these calipers , seal kits are about £30 per caliper , the pad plates can be removed , its just a button head 6mm bolt holding them in.
We charge £95 per caliper to completely strip them down , bead blast , and powder coat them any colour you want , we polish the seals , chemically clean the seals , as long as the seals are still good we can re-use them , if not for extra charge we fit new ones. , we bead blast the pad plates and re-fit them with new bolts , we also fit new bleed nipples.
We can supply you new rotors and a set of nuts and bolts for £295 a pair , as you have one of our kits the rotors will fit directly onto your bells.
Pad wise , there are plenty of pads available for these calipers , I don't rate the yellowstuff pads , but for fast road use , the Blue NDX or DS2500's work well , for fast road and track use we are big fans of CL RC5+
DS2500's are £108 a set
NDX blue's are £135 a set
CL RC5+ are £198 a set
Hope this helps
Cheers Ian
Hope this helps
Cheers Ian
on
Hi Ian, thanks for the reply, sterling rate is a killer at the moment against the euro. Is there any single piece discs that will work with these calipers. I dont mind dropping a bit in size to be honest, car probably wont see track again anytime soon if even!
on
Hi Ian,
Do you have a link to the ones i need on your site so i can order them up? I cant see the euro getting stronger anytime soon! What the easiet way to remove the bell bolts as im sure they will be well seized up at this point!
28 December 2015 11:07 PM
18 November 2015 07:03 AM
